Dumb question.. Common mistake?
machineman
machineman Solar Expert Posts: 129 ✭✭✭
Last week I installed my small 65w solar panel and i used a compass to align it south. Now I realize that's incorrect... I should set it to true south not magnetic south... This is correct right?
Off Grid Cabin, 24V 440ah 6V GC battery bank, Xantrex MPPT60-150 CC, Magnum MS4024 inverter-charger, >1200w Solar bank
    Re: Dumb question.. Common mistake?
    You are correct... Magnetic south varies--depending where on the earth you are. In most areas, it probably does not make a huge difference.
    Here is a 1990 chart of the world magnetic declinations:
    http://www.thecompassstore.com/whatisdec.html
    Here are some more detailed maps of various places in the world:
    http://www.geo-orbit.org/sizepgs/magmapsp.html
    And an older page with lots of links and information:
    http://www.geocities.com/magnetic_declination/
    My panels face west, and because of weather conditions, (foggy AM, clear evenings) produce as much, or more, than if they faced south. It all depends on your micro situation. 10 degrees east or west just means you hit peak power a little before noon, rather than just after noon.
    Your mileage may vary
    a good approximation would be to take the sunrise/sunset times and find the time in the middle. that would be solar noon. if you are within 10 or even 20 miles of that tv or radio station giving that info then it's nearly right on. at that time the shadow cast by the sun will be in a north/south direction and you could even get the elevation angle for that day if you're good with math as the shadow length and the height of the shadow source all would help with the angle the sun is at.
  • crewzer
    You can find the exact magnetic declination for your location using this calculator:
    http://www.ngdc.noaa.gov/seg/geomag/jsp/Declination.jsp
    The “solar noon” approach can be close, but it’s only accurate twice a year (~ Spring and ~Fall) due to the elliptical nature of the Earth’s orbit around the Sun, the related “Equation of Time”, and the resulting analemma (the Sun’s “Figure 8” path in the sky). For example, here's a link to the analemma for Washington, D.C, a bit east of my home: http://jrscience.wcp.muohio.edu/photos/WashDC1997.gif
    As noted, the alignment just has to be close, and your local climate may dictate some other orientation. For example, if you typically experience cloudy mornings and sunny afternoons, you may want to orient the array a bit towards the West.
    You can also use the PV Watts calulator to model various angle "errors". See: http://rredc.nrel.gov/solar/calculators/PVWATTS/version1/
    HTH,
    Jim / crewzer
    yes i did say it was a good approximation. you are correct that it is accurate during the spring and fall equinox.
  • machineman
    I used that NOAA link. Mine is, Declination = 15° 18' E changing by 0° 6' W/year
    Thanks.
  • Windsun
    Being off a bit will not really make as much difference as you might think.
    What the solar panel sees is a result of the CoSine of the angle - for those (like me) that have forgotten their high school math, just look at a cosine table for 15 degrees and you will see .9659 - which means that the panel will get 96.59% of max power at a 15% angle. It does not start getting serious (over 10%) until you get up over 25 degree angle or so.
    http://www.grc.nasa.gov/WWW/K-12/airplane/tablcos.html
  • crewzer
    I think we have a consensus: It just sort of has to be kind of close! :roll: :-o :-D
    Regards to all,
    Jim / crewzer
    would i be risking an abbot and costello routine if i said "exactly"?
