Using a solar panel without a battery
shmuel
Registered Users Posts: 4
I'd like to connect a 19V (max.) solar panel to a female car plug, then plug in a USB car adapter, in order to charge cellphones and the like. Should I attach the female car plug to the load terminals of a charge controller, or are charge controllers meant to be used only with a battery attached?
Any advice would be appreciated.
Re: Using a solar panel without a battery
Charge controllers generally need to be connected to a battery for them to work.
I don't believe that your USB adapter will work properly being connected directly to the PV panel, but I'm sure that our resident experts will chime in soon to correct me if I'm wrong. -
Thanks for your reply.
So how do I prevent the solar panel, which can get up to 19 volts, from frying the USB car adapter, which excepts 12 volts? -
Re: Using a solar panel without a batteryHow do I prevent the solar panel, which can get up to 19 volts, from frying the USB car adapter, which accepts 12 volts?
Solar Panel feeds Charge Controller, which in turn feeds Battery, which then feeds USB car adapter.
Need to know more detail on solar panel before Battery Size and Charge Controller can be suggested. -
In theory, this Anker 12 volt 24 watt USB charger runs up to 24 volt input:
http://www.amazon.com/Anker®-Dual-Port-Charger-PowerIQ-Technology/dp/B00B8M4IMK
I use it in my car for charging various USB phones/tablets/etc... And so far--I have been very happy with it.
It is cheap enough that I would try it and see if it works with a direct solar panel input. If it does not, or "blows up"--Not much is lost.
Thanks. It looks like a very nice adapter. -
One thing to be careful of--Some failures could include allowing 12-24 volts to your USB device... I would use a "cheap" USB device first when experimenting on the rare chance that a USB charger failure could take out the USB load too.
OK, thanks. I have a USB doctor I can use to test the output voltage. -
Wouldn't it be easier simply to use a solar panel that is already optimized for USB charging, such as the Goal Zero Nomad series of panels? -
I like Bill's idea, Since it will handle 24v you likely won't have a problem, I've used a 6v - 5 watt panel with a simple voltage regulator, to charge USB devices with better than good results. Even my fussy Nokia N800 would charge. Says it will handle up to 35v. You could likely strip a heat sink and a USB female out of an old tower. Since most USB devices for lithium regulate the charging I think this would work fine, even with a larger panel.
RatShack 5v regulatorHome system 4000 watt (Evergreen) array standing, with 2 Midnite Classic Lites, Midnite E-panel, Magnum MS4024, Prosine 1800(now backup) and Exeltech 1100(former backup...lol), 660 ah 24v Forklift battery(now 10 years old). Off grid for 20 years (if I include 8 months on a bicycle).
- 219 Forum & Website
- 127 Solar Forum News and Announcements
- 885 Solar Product Reviews & Opinions
- 649 Solar Water Pumping
- 606 Discussion Forums/Café
- 300 In the Weeds--Member's Choice
