not solar but
Novaz
Novaz Solar Expert Posts: 57 ✭✭✭✭
As part of my research about going off grid with solar and other less expensive utilities
I have become really interested in these pumps as like solar they require no real external power other than the flow of water
one of the criteria in my land search is that the property has a creek/stream of some kind
the output of these pumps can seem to be very small over long distances and elevations but it will or can be run 24/7/365 so the amount of water pumped could be more than ample especially when used with a storage system .
Roy
https://www.youtube.com/watch?v=JvqA6zb1k_U
  • zoneblue
    Re: not solar but
    Ram pumps are great when they go, but depending on the build quality and the installation, can take a lot of maintenance. The repititive hammering work hardens the materials until they fail. If you go this route do your homework and find one thats bulletproof, has screeds of glowing testimonials.
  • Alaska Man
    Alaska Man Solar Expert Posts: 252 ✭✭
    Re: not solar but
    Ram pumps remind me of Wood Gasifiers, you can run your truck without gasoline using a wood gasifier, both technologies are old, both work. However there is a reason we have moved on.
    Re: not solar but
    The video is a bit miss leading, the waste involved in pumping from a rain barrel make delivery silly. but from a consistent flow, they should work fine. I haven't seen one up and running in 20+ years in NC. But it worked fine and reportably had been for many years.
