Testing batteries with load tester
jcheil
Solar Expert Posts: 722 ✭✭✭
Can you test individual batteries in a string with one of these without disconnecting all the interconnects?
Off-Grid in Central Florida since 2005, Full-Time since June 2014 | 12 X Sovello 205w panels, 9 X ToPoint 220w panels, 36x ToPoint 225w panels (12,525 watts total) | Custom built single-axis ground mounts | Complete FP2 Outback System: 3 x FM80, 2 x VFX3648, X240 Transformer, FLEXnet-DC, Mate-3, Hub-10, FW500 AC/DC | 24 x Trojan L16RE-B Batteries 1110ah @ 48v | Honda EU7000is Generator and a pile of "other" Generators | Home-Made PVC solar hot water collector | Custom data logging software http://www.somewhatcrookedcamp.com/monitormate.html
Re: Testing batteries with load tester
Yes, as long as the string isn't connected to anything (no load/charging on the terminus). -
jcheil,
How much are those load testers nowadays, in the US?Paul -
jcheil,
$19.99 right now at Harbor Freight.Off-Grid in Central Florida since 2005, Full-Time since June 2014 | 12 X Sovello 205w panels, 9 X ToPoint 220w panels, 36x ToPoint 225w panels (12,525 watts total) | Custom built single-axis ground mounts | Complete FP2 Outback System: 3 x FM80, 2 x VFX3648, X240 Transformer, FLEXnet-DC, Mate-3, Hub-10, FW500 AC/DC | 24 x Trojan L16RE-B Batteries 1110ah @ 48v | Honda EU7000is Generator and a pile of "other" Generators | Home-Made PVC solar hot water collector | Custom data logging software http://www.somewhatcrookedcamp.com/monitormate.html -
You need to "test" each battery for the same amount of time, or you will have to equalize the bank afterwards.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Usual battery bank safety... Wear a face shield and some sort of gloves to protect against acid/flash burns. Assume that at some point, the clamps will generate some sparks. Ventilate the battery box/bank well, cover cell caps with a damp towel or something similar.
Sounds like over kill--But I would rather everyone be safe rather than sorry.
What is the ratio for the mixture to neutralize the acid?
1 pound of baking soda to 1 gallon of water? Am I correct there?Paul -
this little clip on SoC just came in http://www.youtube.com/watch?v=WWzC_yaMHkE&feature=youtu.be
may be of use..
Re: Testing batteries with load testerWhat is the ratio for the mixture to neutralize the acid?
Much less, and applied in several batches. Each reaction causes heat, so too much "base" mixed with "acid" gets you thermal burns in addition to the acid burns.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Don't be too alarmed if things get a little smoky / burnt smelling the first few times you use it.
- 654 Solar Water Pumping
- 619 Discussion Forums/Café
