MorningStar SunLight 12 vdc, 10 amp Solar Charge Controller
ILFE
Solar Expert Posts: 364 ✭✭
Howdy All,
I have a 12vdc, 10amp MorningStar SunLight charge controller.
I have an available 135 watts module. Will that module burn up the controller if I connect it to the the panel? I live in SE Asia, so cold temperatures are not going to happen. I am thinking no, because the Isc is only 8.19 amperes?
Input, please?
Thanks,
Input, please?
Thanks,
Paul
Re: MorningStar SunLight 12 vdc, 10 amp Solar Charge Controller
It should work fine.
Keep in mind it won't work without a battery though. -
LOL. Yeah. The 12vdc battery was already connected to the controller. I was just being cautious prior to changing modules (from 100 watts to 135 watts).
Thank you.Paul
- 230 Forum & Website
