- - - Need advice in replacing SMA 2100U inverter
BillC
Registered Users Posts: 4
Hi all,
My 2100U inverter failed, a few months after the 5 year warranty expired.
I 'get' that it's not worthwhile putting $$ into trying to repair an inverter of this vintage, so I'm looking to replace it.
What are the leading contenders that I should be looking at?
Many thanks,
/BillC
Portland, OR
Many thanks,
/BillC
Portland, OR
Re: - - - Need advice in replacing SMA 2100U inverter
Are you thinking of adding more solar panels at this time? ~2,600 Watt array is not that large these days.
Also, what is the array configuration (panel brand/model, series/parallel configuration)?
I think you will find most give 10 years these days, Fronius, PVPowered .... -
Re: - - - Need advice in replacing SMA 2100U inverterAre you thinking of adding more solar panels at this time? ~2,600 Watt array is not that large these days.
And my array isn't even that large. It's 9 Sharp NE170U1 panels in series-connected arrangement. (Small s-facing roof...)
/Bill -
SMA should still be one of the best/most reliable GT inverters for the US market. And they seem to offer the smallest central GT inverters too.
It is not good that it only lasted 5+ years. The present ones have a 10 year warranty (I am a bit surprised that yours did not have a 10 year warranty too--California has required a 10 year warranty for their subsidized installs for almost 10 years now--last I remember). Have you tried calling SMA support to see if they would help?
There are other GT inverters that are 3+ kWatt but cost less money than the SMAs. They will have somewhat higher losses (larger inverters have higher "tare" or fixed/operational losses)--But probably not a huge issue.
Anything happened that damaged the original inverter (lightning/surges)?
I'm not aware of any incident that fried the unit - one day the Fault light appeared, and nothing I tried has been able to clear it.
The paperwork is pretty explicit about the 5 year warranty term, but I'll call SMA to see if they have any suggestions.
Thanks,
/BillC
Portland, OR -
Here is a post with several people that repair SMA inverters:
http://forum.solar-electric.com/showthread.php?5556-Working-Thread-for-Solar-Beginner-Post-FAQ&p=159835#post159835
You can ask them if it may worth repairing yours or not... (I know nothing else about the folks on the list--Do your own research).
Thanks Bill,
/Bill
- 234 Forum & Website
