What issues are there if solar panels are sitting in the sun with it's feed open...
rgearhead
Solar Expert Posts: 38 ✭
Hi all..... lets say YOUR' system's charge controller fryed, and you switched off the feed from your solar array... now it's going to take you a week to get a new charge controller, So ? will your array be fine, what to do ??
thanks Bob....
thanks Bob....
Re: What issues are there if solar panels are sitting in the sun with it's feed open...
No issues, just make sure the disconnect is safe. i.e. no dangling wires. -
Glad to hear this, thanks Dave'' -
Re: What issues are there if solar panels are sitting in the sun with it's feed open...solar_dave wrote: »No issues, just make sure the disconnect is safe. i.e. no dangling wires.
That assumes silicon based panels. Those toxic CdTe panels can be harmed by sitting with no load at Voc. --vtMaps4 X 235watt Samsung, Midnite ePanel, Outback VFX3524 FM60 & mate, 4 Interstate L16, trimetric, Honda eu2000i -
I let one of my panels sit outside for a few months not hooked up to anything. Works fine.Hi all..... lets say YOUR' system's charge controller fryed, and you switched off the feed from your solar array... now it's going to take you a week to get a new charge controller, So ? will your array be fine, what to do ??
How did you fry your charge controller? Theoretically, of course
Re: What issues are there if solar panels are sitting in the sun with it's feed open...That assumes silicon based panels. Those toxic CdTe panels can be harmed by sitting with no load at Voc. --vtMaps
Pretty safe assumption on solar_dave's part I'd say. :roll: -
Re: What issues are there if solar panels are sitting in the sun with it's feed open...I let one of my panels sit outside for a few months not hooked up to anything. Works fine.
I didn't'' lol,,, I want to put up a Grape 250 watt solar panel tomorrow, but wont get trench dug to run wire's to it till during the week..... Just wanted to make sure it was ok to mount it to get it out of the way while i have help to do so .....
thanks Guy's... Hmm there is no solar Gal's''''' -
If this is one of the Grape panels that requires positive ground for proper operation, then leaving the + and - floating might have some short term adverse effect on panel output. But tying the not yet connected positive lead to ground in the meantime would prevent that. Or just running the panel properly connected for a few hours or days.I didn't'' lol,,, I want to put up a Grape 250 watt solar panel tomorrow, but wont get trench dug to run wire's to it till during the week..... Just wanted to make sure it was ok to mount it to get it out of the way while i have help to do so .....
thanks Guy's... Hmm there is no solar Gal's'''''SMA SB 3000, old BP panels.
- 234 Forum & Website
