can I see your diy pole mount setups?
ahreno
Registered Users Posts: 2
I've been searching for the past half hour for some ideas of how to make a mount for two panels that would go on a pole. I found a design I like but it requires welding which isnt ideal. I'm in northern cali and need about a 45 degree tilt. I'm having a hard time coming up with an idea for attaching the mount to the pole and being able to adjust... Trying to avoid a $300+ mount for two panels.
Re: can I see your diy pole mount setups?
Welcome to the forum AlReno...
Here is a quick Google image search of our forum--See anything interesting?
https://www.google.com/search?q=pole+mount+site:solar-electric.com&client=firefox-a&hs=Xso&rls=org.mozilla:en-US:official&channel=sb&source=lnms&tbm=isch&sa=X&ei=La12U4qICIHhoATSp4KIDg&ved=0CAkQ_AUoAg&biw=1181&bih=565
If that link does not work for you, click on this link and the "Images" button just under the search box:
Some of us have a really big junk shed. Unistrut and old sat dish (1M) mount using a old (thick steel pipe) swing set as the support structure.
https://flic.kr/p/bBMUVP
https://flic.kr/p/bByEv2
https://flic.kr/p/boDKwh
https://flic.kr/p/boSZnq
The base of the pole rides of top of brass plates on a concrete base so it can turn.
https://flic.kr/p/cAMQXb -
Kind of... Not really... I guess a question I have is... If I use unistrut will the pipe clamps that are made for it tighten enough to keep the panels in the right position? I've only got two panels that weigh 40lbs each. -
If you use the proper unistrut clamps it will be plenty strong but you will still need a angle brace from the structure to pipe to keep it from moving from the set angle under heavy load. My sat dish hinge has a adjustable stop bolt to keep it from moving.
They have adjustable ones too. P2815 P1843
http://www.unistrutconstruction.com/pdfs/S05_fitting.pdf
- 621 Discussion Forums/Café
