welding around panels?
davo
davo Registered Users Posts: 21
Hello all,I have a large motorhome with panels riveted to a roofrack which is bolted to the roof,I would like to weld the roofrack in situ, without removing the panels,if I d.c the panels theres no way they could be damaged am I right? Thanks
    Re: welding around panels?
    Aside from sparks destroying the coating on the back and front and insulation on the wires you mean?
    I'd take them off.
    Never tried that, let us know the results.
    In general, modern solar panels have >600 VAC isolation between the panel+wiring and earth/safety ground/metal frame ratings.
    So--Electricity/sparks (electrical kind of interference) should not hurt anything. But any hot slag will not be good (note the panels are generally covered with safety glass--Any scratch or hot slag can cause them to "shatter" like safety glass).
    Heat/welding smoke/Ultraviolet are also possible sources of damage to your array/wiring--But if you can prevent them from getting to the panels/wiring--Should be OK.
    Good grounding to whatever is being welded would be a good idea too (don't want welding current flowing through your aluminum panel frames/RV mounts).
  • Slappy
    Slappy Solar Expert Posts: 251 ✭✭✭✭✭✭
    Weld splatter will pit the glass.
  • CDN_VT
    CDN_VT Solar Expert Posts: 492 ✭✭✭
    I weld , spot ,Mig,Tig, cold depth source , No stick on the new space cars / trucks loaded with CAN Nodes.
    Always make sure the grounding / return clamp is as close to the area of weld/ penetration , clean all ares of contact. Cover any Glass or exposed splatter zone. You should be good .
    The frames of the solars are not connected to the wiring ..
    VT
    I did at one time , weld on R-frames with gas torches , glad were aged and beyond those days.
