MSX-64 Solar Panels
stmar
Solar Expert Posts: 373 ✭✭✭
I have an array of 12 Solarex MSX-64 panels. They are wired for 24 volts. They are 64 watt panels so what are my total watts? I did not know if it was like battery amp hours where voltage determined the value. These panels kept my battery bank (4 - PVX2580 AGMs) charged for a year, all it was running was a Sun Frost RF-16, with no additional charge devices. Inverter was down and had to be rebuilt.
Re: MSX-64 Solar Panels
Watts are Watts: Volts * Amps. So twelve 64 Watt panels is 12 * 64 = 768 Watt array.
When you are looking at battery Amp hours you're only seeing half of the power equation; without knowing the Volts you can't determine the Watt hours.
And note that in the panel equation you are determining only the rate; without the time factor (hours of equivalent good sun) you won't know the quantity of power available (Watt hours) in a day. -
i do hope you are using a charge controller to prevent the overvoltage condition to your agm batteries as agms do not like to be pushed beyond a certain voltage point. -
Re: MSX-64 Solar Panelsi do hope you are using a charge controller to prevent the overvoltage condition to your agm batteries as agms do not like to be pushed beyond a certain voltage point.
- 654 Solar Water Pumping
