From the "that can't possibly pass building code" file
http://www.filehigh.com/viewimg.php?f=26494&i=257826
that's a in-progress pic of one of the PV strings. pictured are (2) SiemAns SR-90s (spelling wrong to avoid UBB word filter modification), and a Sharp-165.
String (2) is (3) Sharp-185s. Everything is 24v nominal except the two SiemAns panels which are in series to make 24v.
Those are simpson footings into a rafter, urethaned, each has a "through" bolt which functions as a seasonal pivot, and the panels are oriented true south. The bottom (in this picture) is the pivot. Yes the frame is just resting on top in the pic, it's secured with bolts now. Not shown is the mechanism at the top for angling the panels which is truly simple: another simpson tie-footing and I have (2) different lengths of lumber. Summer I don't use any and I just secure the pressure-treated lumber frame to the (3) PTL 2"x4" on the roof with bolts. The "fall/spring" adjuster is about a foot offset, and the "winter" one is almost 2'.
I'll take another pic later just wanted to throw up what I had and catch some laughs/flak
I haven't bothered to run the roof loading calculations to see what the building code would require (125# per square foot max?) but really I was focusing on using a stud finder and catching the rafters on each 2"x4" at least in one place--- a true south orientation makes that more difficult than I had thought.
Re: From the "that can't possibly pass building code" fileJoeT wrote:pictured are (2) SiemAns SR-90s (spelling wrong to avoid UBB word filter modification),
Uh. I'm now more interested in the "word filter" and what gets modified. Is there a list of bad PV words here??
That might pass mechanically, never know. Doesn't look that bad to me.
We live in the same city, and you get to have 5 lbs per square foot, which is actually not hard to meet. You also need to have 40 lbs max per support point, and less than 18" above the roof surface. Going outside of these parameters is possible, too, but triggers the need for a review.
And of course, there's always inspector's judgement, but if you have something sturdy, I don't see why there would be a problem. -
Joe,
A couple of observations on your array installation:
1) Unless you live in the Tropics, the relatively small tilt angle will reduce the array's energy output, especially in the Winter. A typical year 'round tilt angle is ~ = local latitude.
2) The lack of space behind the array will reduce natural air circulation that helps to cool the array. This too will cause an output a decrease in energy output.
HTH,
Jim / crewzer -
thks, the array is currently about 20 degrees (tough to see in pics), I made a spring/fall step and a winter step (not pictured)
agreed there's only a 5.5" offset from the roof when mounted 'flat' like this
, I expect underpanel temps to be BAKING in the summer. -
joe,
i am having troubles in trying to figure what part is the bottom/top. in any case i must point out that raising the angle for winter may not have it pointing south even though it will be lower in altitude. please confirm that for yourself.
check that no water can seep into the roof from the bolts, nails, or screws you had used in securing the wood frame to the roof. the feedthrough bolts you may have trouble with if they are standard bolts that could rust. it is better to obtain stainless steel hardware. stainless steel can 'freeze up' on you so a light oil could be used between the washers and bolt heads in addition to between the nuts and washers. also don't forget to ground your pvs. -
Hummmmm, first time I've ever seen PV's nailed to a 2X6. LOL
Just kidding. Looks funny though. LOL
Wayne -
he means decreasecrewzer wrote:This too will cause an output in energy output.
you probably are aware of this but just thought id mention in case. you got the right kind of joisthangers/bolts that are chemicaly compatable with the new treated lumber? something my lkuberyard pointed out to me a few yrs ago the new type of pressure ctreated lumber reacts checically with standard PT. the luber yard can give details.
i thought this looked pretty good, if not esthetically, at least it appears solid. i presume you can not see this from the street. nice neighborhood!
a couple small aluminum L shaped parts from PV mounting hardware kits would give youa couple inches air circulalation -
Re: From the "that can't possibly pass building code" fileWayne from NS Cana wrote:Hummmmm, first time I've ever seen PV's nailed to a 2X6. LOL
Wayne
lol. BOLTED, not that it matters
Just kidding man, you should see some of the abortions I've made in the past. LOL
But like your's, they worked and some still are working. :-D
Wayne -
I'd be a tad concerned about the penetrations to the roof myself. As an ex-roofer, I know how stubborn water can be. Those pressure treated runners the pvs rest on are a perfect situation for leaves to accumulate under the panels and generate an ice dam in the winter, just like unprotected gutters can do. Just my $.02. :-D
