Connecting the Charge Controller for a solar system
terminator
terminator Registered Users Posts: 5
Hello, I'm very new to solar energy. I got a charge controller from China - It probably wasn't the best choice but I just want to get something up and running / to experiment with. There are 3 electrical connections on the charge controller.. Solar, battery, and load... Am I supposed to hook up the inverter to the load connectors on the charge controller or directly to the battery?
Here is my cheap charge controller:
http://www.ebay.com/itm/181345329849?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
  • Vic
    Re: Connecting the Charge Controller for a solar system
    Hi terminator, Welcome to the Forum.
    Generally, NO, the inverter will need its own connection to the battery. You will need a fuse or circuit breaker, and suitable sized wire/cable for the battery to Inverter connections. Look at the manual for the inverter for the recommended sizes for these.
    Vic
  • terminator
    Vic wrote: »
    Vic
    Ok, thanks. Oh, what size fuse (circuit breaker) should I use? and thanks for the welcome!
    edit.. 100w system will be expanded to 300w soon. I'm not sure if I can go to 400w with a 30a charge controller but I already want a different one anyhow.
    We should "do the math"...
    Loads (watts maximum, watt*hours per day, etc.).
    Size battery bank (volts/Amp*Hours)
    Size solar array
    Size AC Inverter
    Size solar charge controller
    Then pick hardware to do the job. There is no direct connection between AC inverter rating and wattage of the solar array+charge controllers.
