Auto-Transformer question.
2»
  • Blackcherry04
    Re: Another auto-transformer question
    Wired in this configuration there would be 120V on the L1 ( black hot ) from the inverter to anything on the L1 Bus. It's fine unless you need 240V all the time and power on the L2 ( red ) side. Say you have a 240V pump and plan to run it manually, just turn the transformer on before you start the pump. If you want it on all the time, move the connection point behind the breaker.
  • verdigo
    verdigo Solar Expert Posts: 428 ✭✭
    Feeling pretty dumb this morning. Maybe I shouldn't fool around with electricity.
  • Blackcherry04
    verdigo wrote: »
    Thats why it's a, trust, but verify when working with electricity. Even when I know, I always test first before touching. Once it becomes a habit, it keep's you safe.
