Backyard Wind Power
mike95490
Solar Expert Posts: 9,583 ✭✭✭✭✭
Discussion at /. refers to an IEEE article about the economics of wind power.
http://ask.slashdot.org/askslashdot/06/10/04/0447231.shtml
IEEE article
http://spectrum.ieee.org/oct06/4661
"Since the dawn of time it has been mankind's dream to blot out the sun"
Montgomery Burns
IEEE article
Montgomery Burns
Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048
inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A
NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole |
Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor
(1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Re: Backyard Wind Power
The picture in the IEEE artical is of my installation. The turbine is a SWWP Skystream 3.7beta and there are 7kwh of solar on the roof.
Carl. -
I'm guessing your off-grid?
brad
no its a grid tie system, the inverter and all control circuits are in the turbine. It communicates via a wireless remote. you can connect the remote to a computer to keep detailed data on whats going on with the turbine from power to rpms and much more.
