Xantrex sw2012 Inverter fault F17 (welded Relay)
Joedog11
Registered Users Posts: 24 ✭
My Question is, Is the relay in the inverter, generator, or the A/C unit.
I was running the generator to power my A/C in my trailer the A/C shut off and came back on then it through the fault. The A/C will come on with the inverter mode enabled with or with out gen running. If I disable the inverter mode and just use the generator the charger light lights up but if I turn on the A/C charge light goes off and the A/C will not work, all you hear is a click from the relay.
Thanks for any help
Joe
Thanks for any help
Joe
Re: Xantrex sw2012 Inverter fault F17 (welded Relay)If I disable the inverter mode and just use the generator the charger light lights up but if I turn on the A/C charge light goes off and the A/C will not work, all you hear is a click from the relay.
Sounds like the generator cannot handle the combined load of the air conditioner and the charger. What happens if you connect the air conditioner directly to the generator (with no other connections to the generator)? If your generator can handle the air conditioner alone, then you may need to adjust the settings on the sw2012 with regards to generator capacity.
When I disable the charger and the inverter, Leave the system in the operation mode the a/c will not run with the generator. The generator I was using is a 5000 craftsman surge 6250 one day old just got it. The a/c and the charger was working fine together with the generator till the a/c shut off I reached over and bumped down the temp maybe a little to fast after it shut off. (like with in one sec, needed to get cooled off.) So the xanbus (scp) will monitor basically every thing not just the inverter? When it trips a fault code F17 it could be in the generator or the inverter?
Generator going back to sears, and is the a place in/or around Quartzsite Az. that can work/trouble shoot on Xantrex under warranty?
Thank you vtmaps -
I have this, The relay that welded is in the inverter. So thank you vtmaps. I will have to send it in for warranty work.
- 654 Solar Water Pumping
- 619 Discussion Forums/Café
