Meter socket types, 4 jaw, 5 jaw ....
mike95490
Solar Expert Posts: 9,583 ✭✭✭✭✭
Ok, so I know they cover single/split and 3 phase systems.
I'm looking for a schematic or convention listing which Jaw is which. I've got a 4 jaw socket, and want to put a meter socket surge suppressor on, which come in different varieties. for some reason, 5 jaw suppressors are $150 less than the 4 jaw.
I'm thinking disconnect #5 lead, and forget it.
Any opinions or thoughts ?
(meter socket suppressors use huge MOV's and are UL listed to 1500A with indicator lights)
Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048
inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A
NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole |
Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor
(1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Re: Meter socket types, 4 jaw, 5 jaw ....
Hi Mike,
I poked around on the net a bit yesterday, but found nothing comprehensive.
Perhaps the mfg of the suppressors would have a diagram ...
You might try this same post in the installer section, also threre are Fourms for electricians etc. I dunno, but this post has been sitting here, so just a BUMP UP.
Good Luck, VicOff Grid - Two systems -- 4 SW+ 5548 Inverters, Surrette 4KS25 1280 AH X2@48V, 11.1 KW STC PV, 4X MidNite Classic 150 w/ WBjrs, Beta KID on S-530s, MX-60s, MN Bkrs/Boxes. 25 KVA Polyphase Kubota diesel, Honda Eu6500isa, Eu3000is-es, Eu2000, Eu1000 gensets. Thanks Wind-Sun for this great Forum. -
I purchased one of the 5 jaw models but I haven't installed it yet. It looks like the 5th jaw is for neutral. The instructions for the 4 jaw leviton say to connect the neutral pigtail to the neutral line from your panel. Perhaps I could remove the 5th jaw and make a pigtail to connect to the neutral bus in my panel. -
I removed the 5th jaw and attach a pig tail wire which was run to the grounding lug upon installation.I purchased one of the 5 jaw models but I haven't installed it yet. It looks like the 5th jaw is for neutral. The instructions for the 4 jaw leviton say to connect the neutral pigtail to the neutral line from your panel. Perhaps I could remove the 5th jaw and make a pigtail to connect to the neutral bus in my panel.
- 227 Forum & Website
- 617 Discussion Forums/Café
