What the process for adding an mc4 connection to pv cable?
nobody928
Solar Expert Posts: 62 ✭✭✭✭
I cant find any clear directions on what needs to be done to install the metal inserts to the wire. How much wire do you strip to get a good connection before crimping? Is soldering necesary? Looking for detailed instructions or an active link.
Thanks in advance.
Thanks in advance.
Re: What the process for adding an mc4 connection to pv cable?I cant find any clear directions on what needs to be done to install the metal inserts to the wire. How much wire do you strip to get a good connection before crimping? Is soldering necesary? Looking for detailed instructions or an active link.
Thanks in advance. -
This a link to a video of the crimper that I use, it also includes information on the strip length and good detail of the whole process.
http://www.youtube.com/watch?v=W4yGfszChCA -
Buy the new SMA Transformerless inverter, they give you a free little MC4 tool with each one! -
Re: What the process for adding an mc4 connection to pv cable?The right way is to use a crimper designed for it - no soldering - but those crimpers are expensive ~$600.
I did a quick google search for mc4 crimper and found many for ~60 ???Off-Grid in Central Florida since 2005, Full-Time since June 2014 | 12 X Sovello 205w panels, 9 X ToPoint 220w panels, 36x ToPoint 225w panels (12,525 watts total) | Custom built single-axis ground mounts | Complete FP2 Outback System: 3 x FM80, 2 x VFX3648, X240 Transformer, FLEXnet-DC, Mate-3, Hub-10, FW500 AC/DC | 24 x Trojan L16RE-B Batteries 1110ah @ 48v | Honda EU7000is Generator and a pile of "other" Generators | Home-Made PVC solar hot water collector | Custom data logging software http://www.somewhatcrookedcamp.com/monitormate.html -
Re: What the process for adding an mc4 connection to pv cable?I did a quick google search for mc4 crimper and found many for ~60 ???
I keep the lawyers away from my crimps.
My MC4 crimper came from ebay and cost $58. It works perfectly. -
Re: What the process for adding an mc4 connection to pv cable?I keep the lawyers away from my crimps.
Re: What the process for adding an mc4 connection to pv cable?Blackcherry04 wrote: »I doubt you'd be suing yourself from a roof fire caused by bad crimps.
If I did, I'd charge myself $500 per hour.:p
Seriously though - I have no doubt that the quality of my crimps are just as good as they would be with the $600 tool. If someone doesn't feel confident in their ability to judge the quality of the crimps they do then an overpriced tool is not going to help. Yes - you should use a good ratcheting crimping tool with a MC4 specific die, but paying for a "name branded" one really isn't necessary IMHO.
- 244 Forum & Website
- 653 Solar Water Pumping
- 628 Discussion Forums/Café
