I made the switch to 24volt but have a few questions.
nobody928
Solar Expert Posts: 62 ✭✭✭✭
I have 4x140 watt panels. I also Have 4 x 105 agm watt east pen batteries. I have a 24v 300 watt sine wave inverter.
What charging paramiters should I be using for bulk and float?
What is the lowest voltage I can draw my battery bank down to before I need to hook up my battery charger and generator?
Re: I made the switch to 24volt but have a few questions.
model number of that battery and the loads you are going to have would help immensely to let us work up an answer to your questions...
- 230 Forum & Website
