I made the switch to 24volt but have a few questions.
nobody928
Solar Expert Posts: 62 ✭✭✭✭
I have 4x140 watt panels. I also Have 4 x 105 agm watt east pen batteries. I have a 24v 300 watt sine wave inverter.
What charging paramiters should I be using for bulk and float?
What is the lowest voltage I can draw my battery bank down to before I need to hook up my battery charger and generator?
Re: I made the switch to 24volt but have a few questions.
model number of that battery and the loads you are going to have would help immensely to let us work up an answer to your questions...
West Chilcotin, BC, Canada
