Christmas Solar
David and Laura
Solar Expert Posts: 139 ✭
House: 2x SMA SI 6048 w 24x 2V DEKA Unigy II; 2x SMA SB 3000TL-US w 24x Sharp ND-H235Q2
Cabin: 1x Magnum MS4024 w 24x 2V DEKA Unigy II; 1x Morningstar TS-MPPT-60 w 6x Sharp ND-H235Q2; 1x 200 Watt Harris microhydro
Intertie: 1x SMA WB 3800; 1x Lambda GEN-600 DC Supply; 2x PSL pQube
Re: Christmas Solar
very nice.
hey, somebody has to act like a beacon for santa right?;) -
Re: Christmas Solar
Maybe you described why before, but if not, why the wire around/under the array?
ralph -
Re: Christmas Solar
my thought on that would be because it was easier. in viewing the array a regular extension ladder would be resting directly against the pv frame and could put undue pressure on them, so it would need a very tall stepladder instead that he may or may not have. -
Re: Christmas Solar
I am guessing critters. -
Re: Christmas Solar
They explained it in another thread: code requirement to keep animals and children away from the equipment and high voltage. It was either put the mesh on the back of the PV panels or make a cage around the array. -
Re: Christmas Solar
That's correct. Putting up the wire mesh around the array was required for us to comply with our local code, and by enclosing in the entire array, it also prevents animals from staying under the array for shelter, and making a mess of the ground.House: 2x SMA SI 6048 w 24x 2V DEKA Unigy II; 2x SMA SB 3000TL-US w 24x Sharp ND-H235Q2
Intertie: 1x SMA WB 3800; 1x Lambda GEN-600 DC Supply; 2x PSL pQube -
Re: Christmas Solar
sorry as i thought ralph was asking why you put the Christmas lights low around the array.
- 227 Forum & Website
- 618 Discussion Forums/Café
