D/C hydro pump size
GreenPowerManiac
Solar Expert Posts: 453 ✭✭✭
Anyone know a good D/C 12v pump strong enough for 13' total head pressure and about 200' of 1/2" pex line ?
Re: D/C hydro pump sizeGreenPowerManiac wrote: »Anyone know a good D/C 12v pump strong enough for 13' total head pressure and about 200' of 1/2" pex line ?
How good? There are a wide range of pumps and qualities. Some pumps can be run dry, some pumps are more tolerant of silt and sand, some are more efficient, come are continuous duty, some are submersible, some can be run solar-direct without a battery, etc.
What is your application?
Geothermal. 20 gallon drum of RV coolant. 1/2" pex lines 200', 7' underground lines, 160' of that. 6' rise above tank.Nature's Design & Green Energy on FaceBook : Stop by and "Like" us anytime.. Many up-to-date articles about Renewables every day.
Lots of DIY Renewable Energy Projects on ETSY : Solar Panel builds, Wind Turbine builds, Rain Barrel build,etc. -
This pump should be able to do it. I pump the pink stuff 80 ft @ 60 psi with it. Usually with a pump like this it's the suction lift that limits you, It'll push 100 time's farther than it can lift. While they are self priming, it's best to help them by filling the line a little, once they are wet, they'll take off. A dry pump never works all that good.
http://www.energybay.org/aquatec-550-pressure-pump-12vdc -
Got anything with about 40 lbs head pressure?Nature's Design & Green Energy on FaceBook : Stop by and "Like" us anytime.. Many up-to-date articles about Renewables every day.
Re: D/C hydro pump sizeGreenPowerManiac wrote: »Got anything with about 40 lbs head pressure?
K. Only need 20 psi.Nature's Design & Green Energy on FaceBook : Stop by and "Like" us anytime.. Many up-to-date articles about Renewables every day.
Re: D/C hydro pump sizeGreenPowerManiac wrote: »K. Only need 20 psi.
Are you talking about a DC circulator pump ?? Thats a whole different animal. I'd use a 120V and a small inverter. Forget the DC.
http://solar-catalog.com/pumps_circulating.html#DC_CIRCULATOR_PUMPS
http://www.amazon.com/Solar-Circulation-Pump-Topsflo-15PV/dp/B005EU7ONM
http://www.thesolar.biz/dc_hot_water_circulating_pumps.htm
First one too big.
2nd one already have and inadequate.
3rd one too expensive.
The first idea should be fine.
Will try thatNature's Design & Green Energy on FaceBook : Stop by and "Like" us anytime.. Many up-to-date articles about Renewables every day.
Ok, I'v built several geothermal / hydronic type systems over the years from 10 gallons to over 1000. Generally if your having pumping issues there is a air lock somewhere. Once the pump is flooded and the piping is full ( no air ) the head pressure goes away. I currently have a 60 gallon closed loop system with 2 hot water heaters ( one gas, one electric ) and a circulator pump and a hydronic coil in the duct to assist a air / air Heat Pump . Good Luck to you on your project. -
With the topsflow pump got lots of air at first and some trickle coolant then stopped. Won't start moving again until after 20 pounds.
Head pressure feet calculates to 38 total. Am assuming it'll work effortlessly when lines purged.Nature's Design & Green Energy on FaceBook : Stop by and "Like" us anytime.. Many up-to-date articles about Renewables every day.
Re: D/C hydro pump sizeGreenPowerManiac wrote: »With the topsflow pump got lots of air at first and some trickle coolant then stopped. Won't start moving again until after 20 pounds.
Head pressure feet calculates to 38 total. Am assuming it'll work effortlessly when lines purged. -
Just bought one of those aquatec pumps.
I'll try and use it on my loop field to purge that too. 4200' length with 3/4" lines.Nature's Design & Green Energy on FaceBook : Stop by and "Like" us anytime.. Many up-to-date articles about Renewables every day.
- 651 Solar Water Pumping
- 611 Discussion Forums/Café
