Which Direction Should Solar Panels Face?
RSSfeed
Registered Users Posts: 3,810 ✭✭
A new study from Austin’s Pecan Street Research Institute finds that residential solar PV panels oriented to the West may have more The post Which Direction Should Solar Panels Face? appeared first on Solar Feeds.
go to solarfeeds for the rest of this story>>>>>
More...
More...
Re: Which Direction Should Solar Panels Face?A new study from Austin’s Pecan Street Research Institute finds that residential solar PV panels oriented to the West may have more benefits for homeowners. . .
No surprise there, and a common strategy in any place that has morning fog/clouds. -
I knew that back in 2006 !Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
