Need Crimper for 12 AWG to 4 AWG Wire Sizes
ftm1776
ftm1776 Registered Users Posts: 3
Any suggestions on an economical crimper that does an adequate job on 10 to 4 AWG terminal connectors??
Or reference to a do-it-yourself method???
  • NorthGuy
    Re: Need Crimper for 12 AWG to 4 AWG Wire Sizes
    This one worked well for me.
  • solar_dave
    Our sponsor sells a reasonable priced crimping tool. http://www.solar-electric.com/hacrtoforlal.html
  • ftm1776
    I've looked at the impact type crimper, but would prefer the precision and control of a "pliers" type crimper.
    Thanks for the suggestions, though.
    then you want to go for a hydraulic crimper. I have one like this one ( not a recommendation for any specific one)
    http://www.ebay.com/bhp/hydraulic-crimping-tool
    and it works well up to 2/00. Bought mine in Canada though.
  • 8n-bob
    8n-bob Solar Expert Posts: 35 ✭✭
    Not endorsing it and I do not own one but just happened to see it.
    Harbor Freight has a hyd. crimping tool.
    Goes from 14awg to either 0 or 00
    BobO.
  • Blackcherry04
    Any of these China hydraulic tools with a 70MM die will crimp 4/0 Welding cable with Standard Battery Lugs. They will not crimp Lugs that are called HEAVY DUTY Lugs ( thick barrel, that no one uses anyway ). Even the standard lugs are a little tricky to get in between the dies, but once figure them out it's easy to do, wiggle the post hole end in first.
  • etcm
    etcm Registered Users Posts: 11
    I got mine at HarborFreight (http://www.harborfreight.com/hydraulic-wire-crimping-tool-66150.html) . One similar to the eBay link and I used a 20% off coupon when it was on sale. It says up to 0 gauge but I used it with 2/0 and with heavy duty lugs (the thick ones). It was tricky with those as I had to apply pressure at two places on the lug (but still along the same circumference line) worked great.
  • peakbagger
    peakbagger Solar Expert Posts: 341 ✭✭✭
    I got a harbor freight hydraulic type crimper so I could crimp my splices on my grounding cables. I used Burndy splices and had to grind out one of the die heads to fit the burndys. Not exactly to code as the die is supposed to match up with the splice but in my area most electricians use split nuts (not code for ground splices) so everyone was happy that I crimped mine.
  • DMJ72
    DMJ72 Solar Expert Posts: 131 ✭✭
    This hydraulic crimper works VERY well, I love it.
    http://www.amazon.com/gp/product/B00EA6GU9U/ref=oh_details_o00_s00_i00?ie=UTF8&psc=1
  • tons001
    tons001 Solar Expert Posts: 71 ✭✭
    This one works well for me.
    http://www.temcoindustrialpower.com/products/Crimpers/TH0006.html
