Fork Lift traction batteries
CaptClarke
Registered Users Posts: 7 ✭✭
The heavy traction batteries for fork lifts seem to be a good value for both capacity and life expectancy. There must be a downside. What might be the problems with something like a 12-85-13 traction battery for RE use (24v 804 AH and about 1100 lbs)
Re: Fork Lift traction batteries
There is nothing wrong with them if you can deal with the size and weight. They are a bit hard to charge with the sun hours available most places. Being a tall case they need a long charge at high current to keep the sg's even and not stratify. They don't have a lot of extra water capacity and need watering often. They can last a long time if you care for them.CaptClarke wrote: »The heavy traction batteries for fork lifts seem to be a good value for both capacity and life expectancy. There must be a downside. What might be the problems with something like a 12-85-13 traction battery for RE use (24v 804 AH and about 1100 lbs) -
It's possible to get them split into two 12 volt batteries at about 600 pounds each, that makes them little easier to handle. -
I was thinking about 2 12v units to make moving them easier. Thanks all for info
