Wire Size
hemmjo
hemmjo Solar Expert Posts: 94 ✭✭
I need to make some cables to send down to the Dominican Republic for a mission I work with. We need a temporary generator/charger/battery/inverter set-up for refrigeration. We already own the generator, charger and refrigerator. So all we need to get this going is an inverter and batteries. The cables I need will connect the batteries to the charger, and batteries to the inverter. In the spring we will be able to add solar panels and a charge controller to eliminate the need to run the generator every few days.
The charger, Iota DLS-30, does not specify wire size but max output is 30amps.
The inverter, MorningStar SureSine 300-115 calls for #6 wire.
I am confused by a couple of wire size charts I have found to choose wire size for the charger.
http://www.solar-electric.com/electrical-characteristics-awg-copper-wire.html
According to the chart above, max for #6 is 37 amps
According to the chart below, max for #6 ranges from 50-75 depending on insulation.
http://www.cerrowire.com/ampacity-charts
I can use all #6 for this project since the lengths are so short, but I am wondering why the difference in specifications?
Thanks,
John
Two systems in the Dominican Republic  http://villagemountainmission.org/
installed Feb 2014 at 19.796189° -70.893594°, Classic 150 + WBJR, KISAE SW1210, MN Battery Monitor, IOTA DLS 55/IQ4,  4- Solar World 275w, 4-6v x 225ah Trace Batteries
installed Feb 2015 at 19.795733° -70.893372°, same components  as above
Honda PowerMate PC0497000, 7000/8750w generator - powers the well and chargers maybe once a week
    Re: Wire Size
    don't buy any more yet!
    look into a combo Inverter/charger, that can be programmed to use 80% of the generators rated capacity, 30A of charger @ 120V is only about 500W when you factor in the POWER FACTOR of the Iota.
    And unless you KNOW for a fact, that the suresine WILL START your fridge, in most cases, even it's 600w surge, can't do it.
    There are a couple of great threads here, one about Generator Sizing and one about Generator Support (assist) of loads, by the inverter.
