sotfware for the design
andersondiaz
Registered Users Posts: 22 ✭✭
Re: sotfware for the design
What sort of software are you looking for?
Some folks around here find Google Draw to make the single line / mechanical drawings for solar power systems.
I believe there is a product called Sketchup which is nice for 3D drawings... Not sure if it used to be a Google product or not.
When I drew our system I used a free program that is called TinyCad
http://sourceforge.net/projects/tinycad/
I found the download link at source forge, it is really easy to use and and does what all the big and expensive software does for free. Give that a try it should do all that you need it to do.
ITJIn Niger, trying to keep a LG FMA 102NAMA fridge(This has the inverter compressor) backed up with solar using a Victron Multi-Plus Inverter/Charger Compact 12v 1600w with a 70a charger built in.I want to back it up for 4-8 hours. I am also running a few O2 cool fans and a few Thin Lite LED's of my batteries for when the grid is down so my kids can sleep. -
Re: sotfware for the designandersondiaz wrote: »hello,
some free sotfware for the design of a photovoltaic system? -
Re: sotfware for the designinthejungle wrote: »When I drew our system I used a free program that is called TinyCad
ITJ
I don't have any experience with that software but I have my doubts that free software does everything that AutoCAD can do. Some of it, I can believe. -
I would suggest avoid using software for the design and balance of the system. This will help you get better understanding of interaction of parts, and thus will help you design better system.
- 651 Solar Water Pumping
- 611 Discussion Forums/Café
