differences between outback inverters
upa123
upa123 Registered Users Posts: 17
I have an opportunity to acquire a GFX3648 inverter under some very good terms. My application is completely off grid site. I understand the GFX series inverters have off grid, on grid and grid interactive capability. Is there any reason I should not get this GFX inverter vs a dedicated off grid VFX inverter ? I have read the online manuals and I just want to make sure I am not missing some major disadvantage. Thank you kindly for any advice.
  • stephendv
    Re: differences between outback inverters
    I only know of one issue: it expects grid quality input on it's AC input when charging. In other words you'd need an inverter generator like the honda EU if you want to use a generator with it. Normal small gensets typically won't meet the narrow frequency or voltage requirements.
  • upa123
    stephendv wrote: »
    Ah, perfect thank you. I already own an assortment of gennys including an EU, so I think this may work.
  • gww1
    gww1 Solar Expert Posts: 963 ✭✭
    One other thing. The manual states they can't be wired in parellel with an 240 (dam, can't think of the name) tingamagig that turns 120 volts to 240 volts. The G inverter is what I have and how you want to use it is how I am using it. It just means I will have only 7200 watts and one inverter won't sleep when using low 240 volt power. That will perhaps cause a few extra watts of loss.
    Cheers
    gww
  • verdigo
    verdigo Solar Expert Posts: 428 ✭✭
    Can you use A PSX-240 with one GVFX3648?
  • Blackcherry04
    verdigo wrote: »
    Yes, not a problem.
