Happy equinox
zoneblue
For all those whose arrays face the equinox solar noon, todays the one of two brief moments each year when the true angle of incidendence (AOI) is zero. Drat it, i was 10 minutes late to take this image from behind the array.
  • solar_dave
    Re: Happy equinox
    Today was the best production I have seen in quite a while. Temps stayed under 100F with a nice steady breeze blowing all day to keep the panels cooler. Plus the consumption was also down, the AC units are doing much better in these conditions. From what I can tell on the predicted temps we only have about 2-3 weeks of AC season left. Finally the lows tonight are predicted to be about 65-68 F so opening the house up in the morning will be a great relief.
    Re: Happy equinox
    zoneblue,
    couldn't you have cheated a bit by moving the camera over a tad and tilting the angle a bit?;) we wouldn't be able to tell.
    also , weird how from your pvs the tracking goes from right to left whereas ours goes from left to right.
    solar dave,
    i'b be happy to send some of our temps down to you right now as it's 54 f.
  • zoneblue
    Re: Happy equinox
    Well you can see by the shades of grey on the sides of the frames that the cameras up and down centrality is about right, the left to right is a bit off. That the tilt is right is no surprise as the tilt was determined using autocad. As for the azimith, the cameras a bit off there, and, as it determined with a hiking grade compass (adjusting for magnetic N), its going to be a up to 5 degrees. Will check it again tomorow if its sunny. Time of solar noon you can get from http://www.esrl.noaa.gov/gmd/grad/solcalc/
    Was quite sunny too, so much power waiting for uses.
    Re: Happy equinox
    actually i like the pic as it is artistically. i also think it would make a great avatar for you.
  • solar_dave
    Re: Happy equinox
    niel wrote: »
    zoneblue,
    solar dave,
    Well it is after 10PM, finally the temps are cool enough to open the windows, I ran around and shut down all the AC units. I am on my patio no shirt, in shorts, comfortably cool out. I bet I will want a tee shirt in the morning! :D
    Re: Happy equinox
    funny because it got cool enough for me to run around and close my windows this morning. at this moment (noon) it's again 54 degrees and will be around 44 tonight.
