Cleaning Panels????
jimShaw
Registered Users Posts: 18 ✭
I did a research on this forum and did not find any info regarding cleaning panels. I know it should be here but nothing popped up.
I have 22 panels installed and love taking $$$ out of So. Cal. Edison's pocket.
Now that I am an owner, I want to keep the panels clean for better production.
To clean, what I have been doing is to take a garden hose with a high pressure nozzle and spray the panels with lots of water every 3-4 months. This is what was recommend by the installation company because they said there is a film over the panels and to do anything more might scratch the film.
Is what I am doing good OR do you recommend something else?
For those who like information.
Panels: Canadian Solar, model C55P-235P, rating 206.7 W-ptc
Emphase Energy: model M215-60-2LL-52X, rating 215 W-AC
Array Rating: Efficiency 96.0%, 4,547.4 W-ptc
System Rating: 4.366 kW
Re: Cleaning Panels????
You're good. The company gave you correct info about the film. Avoid harsh chemicals, but you can use a mild detergent and even window cleaner if needs be. Most of the time they won't need any cleaning. Normal dust has little effect on production. Heavier layers or things like leaves/tree pollen will.
One caution is to not hit them with water when they are hot or producing: then you have the double problem of thermal shock and the water 'lensing' causing concentration of light on cells. It won't absolutely damage anything, but it increases the risk. -
I've never cleaned my panels, except for snow, and they look very clean :cool: -
I thank you for your knowledge.
Yes, I have been careful. I wait until the sun is almost down in the late afternoon and not on the panels. I do a test with the garage door which is in direct sun light. If the door has cooled down to the touch, that is when I spray.
Once again, I thank you. -
Yep that is all I do, usually early morning when the panels are still cool. We do get a slight increase in production after cleaning but we get Haboob. -
Re: Cleaning Panels????I've never cleaned my panels, except for snow, and they look very clean :cool:
Excellent. Thanks, NorthGuy -
Re: Cleaning Panels????solar_dave wrote: »Yep that is all I do, usually early morning when the panels are still cool. We do get a slight increase in production after cleaning but we get Haboob.
Thanks, Solar Dave
This might be a solar term that I am not familiar with Haboob What the heck does it mean?:D -
Re: Cleaning Panels????Thanks, Solar Dave
This might be a solar term that I am not familiar with Haboob What the heck does it mean?:DA haboob (Arabic: هَبوب "blasting/drafting") is a type of intense dust storm carried on an atmospheric gravity current. Haboobs occur regularly in arid regions throughout the world.
This is one blowing into Phoenix.
This one is coming into the east side of town.
http://bcove.me/u6ivxs5q -
Holy Cr-p. After that goes by, everything has to be washed -
Re: Cleaning Panels????Holy Cr-p. After that goes by, everything has to be washed
You certainly want to make sure the house is closed up tight. The wife is a Virgo and the hose gets about a 2 hour work out cleaning everything after one. I have seen the day after cars churning up the dust on the roads from a heavy one. -
wow. idea---put the pots and pans on a clothesline and let them get pelted clean. i gotta admit i didn't think of it as it was featured on a star trek episode. -
Re: Cleaning Panels????wow. idea---put the pots and pans on a clothesline and let them get pelted clean. i gotta admit i didn't think of it as it was featured on a star trek episode.
That would do it.
I remember once, many years ago, I was driving from Las Vegas to California when a dust/sand storm hit. It sure cleaned the paint off the car. Made the once blue car a very shiny silver/metal color. -
I want to thank each and everyone of you for your input and advice. It helped tremendously.
m -
Jim, imagine what a paint and body shop would charge for that valuable prep-before-paint result:cool:
Ralph -
I wash off my panels in the early AM, about 1x a month in the summer. Just a hose and high pressure nozzle. In the AM, they are often damp from dew, and clean easier. If you have hard water, you CAN use a car wash DI (de-ionised) rinse like from a Mr Clean car wash unit.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
- 611 Discussion Forums/Café
