Solar charging a 36V battery
rmcinnis
Registered Users Posts: 1
I have an application where I would like to use a solar panel to maintain the charge on a 36V battery pack.
This battery pack is used in a "pedicab" like vehicle, which includes pedal assist, and tends to get driven short distances and then left to sit for 30 minutes to an hour. This cycle repeats throughout the day and into the evening. There is NO A/C main system (Grid) available at all and very little opportunity to utilize generator for recharging. The vehicle has a "roof" of sorts that would be suitable for mounting a solar panel, and I was thinking of something in the 80 to 100 watt range.
The battery back consists of 3 20 amp-hour sealed lead acid batteries.
The problem is the 36 volt system. I find lots of solar charge controllers at 12, 24 or 48 volts. Are there any that will handle 36 volts?
I had considered adding another 12 volt battery, and then have the panel charge the 12 volt which would then feed an inverter to power a 36 volt charger. But that seems horribly inefficient, more weight to haul around, more cost and more difficult to operate.
Rod
Rod
Re: Solar charging a 36V battery
Welcome to the forum Rod.
Yes, there are controllers that can be programmed for 36 Volts. There's the rub; programmed. We are talking about more expensive MPPT type controllers in the $500 range. That would be a bit ridiculous for this application.
What you have there is three 12 Volt batteries in series. So a cheap work around would be to use three small panels with a controller each and make sure they don't share common negative or positive. For full charging you'd want a panel that can put out about 2 Amps, which would be around 35 to 40 Watts (three of them like this: http://www.solar-electric.com/so40wa12vomu.html) and three small controllers to go with them (like this: http://www.solar-electric.com/sg-4.html).
It's not a perfect solution. The small panels cost a lot more per Watt, tend not to be the more efficient monocrystaline type, and won't charge the batteries as a whole bank but rather as three individuals. But it is better than no charging. -
XW-MPPT60-150 controller can be configured for 36V, but it's probably too big for you.
You may be able to trick a 48V or 24V controller if they have wide parameter ranges. For example, I have 48V battery bank, but I told my solar charge controller that my battery is 60V. I then lowered all the voltage settings so that they would be too low for real 60V battery, but work well for my 48V battery.
I searched the Web, and there are some very cute 36V chargers available. -
Re: Solar charging a 36V batteryThe problem is the 36 volt system. I find lots of solar charge controllers at 12, 24 or 48 volts. Are there any that will handle 36 volts?
One problem you may have is finding a panel that has high enough voltage to charge a 36 volt battery. A company called Genasun makes boost charger controllers for golf carts that can charge a 36 volt battery from a panel with lower than 36 volt output.
I have a similar need, charging a 36v golf cart out of solar power. I found in my garage 3 old panels that seem to be in good shape. My tester shows 12.3 Volts (open circuit).
What if I connect the three panels in series and connect this series to my cart´s battery bank? I don´t think I need a controller, do I ?
Thanks. -
Re: Solar charging a 36V batteryI found in my garage 3 old panels that seem to be in good shape. My tester shows 12.3 Volts (open circuit).Home system 4000 watt (Evergreen) array standing, with 2 Midnite Classic Lites, Midnite E-panel, Magnum MS4024, Prosine 1800(now backup) and Exeltech 1100(former backup...lol), 660 ah 24v Forklift battery(now 10 years old). Off grid for 20 years (if I include 8 months on a bicycle).
12.3 volts for open circuit is very low for a modern panel. It sounds like they may be designed for charging a ~6 volt battery. Or three in series would charge about 18 volts worth of batteries.
At this point, you really should look at a new set of panels (and probably charge controller) if you want to charge the cart. What size battery bank are you looking at (~210 AH @ 36 volts)?
When that doesn't work I have a 36 volt 21 amp quiq battery charger I am selling cheap.
You can use that and a generator or grid to charge your batteries.
I used this kind of battery charger for years to charge floor scrubber machines and tugs, I also hear they are very popular for golf cart charging. They easily out lasted the batteries they charged.Solar hybrid gasoline generator, 7kw gas, 180 watts of solar, Morningstar 15 amp MPPT, group 31 AGM, 900 watt kisae inverter.
Re: Solar charging a 36V batteryI have an application where I would like to use a solar panel to maintain the charge on a 36V battery pack.
Rod
Here is a nice 30 amp CC that may meet your needs, very happy with mine.
http://www.roguepowertech.com/products/chargecontrollers/mppt/mpt3048.htm510 watt pv, TS-MPPT 60, Exeltech XP1100, XP600 & XP250 @ 24V, 4x Trojan 105RE, Trimetric 2030, Yamaha EF2400i gen.
- 228 Forum & Website
- 654 Solar Water Pumping
- 619 Discussion Forums/Café
