End Absorb : Fixed Time or End Amps?
Re: End Absorb : Fixed Time or End Amps?No, the Outback FM60 cannot see this however, it will assist me in manually setting the absorb end amps based on average background loads during charging.
ok, is perfect ... but you should be even more careful than usual (i mean typical lead-acid batt), in the configuration to finish stage absorption with these, more critical, gel batteries.
- 628 Discussion Forums/Café
