End Absorb : Fixed Time or End Amps?
2»
  • unicornio
    unicornio Solar Expert Posts: 217 ✭✭
    Re: End Absorb : Fixed Time or End Amps?
    SandyP wrote: »
    No, the Outback FM60 cannot see this however, it will assist me in manually setting the absorb end amps based on average background loads during charging.
    ok, is perfect ... but you should be even more careful than usual (i mean typical lead-acid batt), in the configuration to finish stage absorption with these, more critical, gel batteries.
