Battery cooling/warming
TexasDan
Registered Users Posts: 10 ✭
Has anyone sunk their batteries part way in the ground to keep them cooler or warmer?
Re: Battery cooling/warming
Yes, people have done it here (not me, I am Grid Tied) and the deeper you go, the more stable the temperatures.
Some issues--Drainage/flooding, ventilation, ability to get large cells/batteries into a "bunker", etc.
http://www.builditsolar.com/Projects/Cooling/EarthTemperatures.htm
Remember that earth is a pretty good insulation--So if you have something generating heat--You may still need positive ventilation (or a large enough bunker) to dissipate the heat.
Re: Battery cooling/warmingHas anyone sunk their batteries part way in the ground to keep them cooler or warmer?
Yep.
http://www.casanogaldelasbrujas.com/blog/2009/03/26/shed-walls-and-water-proofing/
http://www.casanogaldelasbrujas.com/blog/2009/05/17/generator-exhaust-expansion-chamber/
You can see the earth covered shed in the background bottom right of this photo:
http://www.casanogaldelasbrujas.com/blog/wp-content/uploads/2011/06/solarview1.jpg
During summer the batts don't get warmer than 25C, even when ambient reaches 35C. In winter they can dip down to 10C when ambient is -5C.
