Its time to start hanging some panels.
verdigo
Solar Expert Posts: 428 ✭✭
Does anyone have any pictures or know of an off the shelf adjustable mounting system to be used on my metal roof. The ground mount I can just do with Stainless angle. The roof is approx 30 degrees, and I want to be able to adjust to 50-55 degrees. The panels measure 77" x 39" and will be mounted longitudinally in two pairs.
Re: Its time to start hanging some panels.
what about the S-5 system, http://www.s-5.com/home/index.cfm
the PV part can be used with regular strut from Acklands (pricey) or other supply houses, many brands, Uni-strut, etc
Re: Its time to start hanging some panels.westbranch wrote: »what about the S-5 system, http://www.s-5.com/home/index.cfm
Pretty nifty, but I worry about wind. I don't mind drilling through the roof. In fact I plan to construct hard points at the penetrations between the rafters so that if the wind takes the panels it takes the roof with it.
Thanks for the reply though.
Dennis -
You made a really good progress since you last posted the pictures of your shed.
If you're afraid of the roof flying away with panels, have you used hurricane ties on the rafters? -
I am a pretty big fan of IronRidge XRS mounting rails.
http://www.ironridge.com/products/roofmounting/overview -
Re: Its time to start hanging some panels.You made a really good progress since you last posted the pictures of your shed.
I do have hurricane ties. What I meant was that if the wind blows hard enough to take the panels it would be strong enough to take the roof as well meaning that I want my panels very well secured to the roof. The mount system westbranch mentioned only clamped to the existing ridges in the metal roofing material with no penetrations. -
Not quite, the PV clamp part can be used with 'strut ' material which can be secured to the trusses. See this link:
http://www.s-5.com/solar/index_2483.cfm#30
I just ordered (from NAWS) the Iron Ridge PV mount set-up. When it arrives I can post pics of the assembly process if anyone is interested. -
I love installation pictures.
gww -
Yes, please post pictures. I too have struggled with tilt-mounting panels on a steel roof -- I didn't want to pay the Iron Ridge price. -
I didn't either but I have so little time to actually work on my system that I figured it would save me some time. I only have two of these grape panels and I want to get them out in the sun and see if I will stay with the brand. Yeah $680ish shipped and all from NAWS with all the hardware. Once I get those mounted I am going to hook up the charge controller and charge some batteries, and get some measurements, I figure with the holiday I won't get the Iron Ridge stuff for another week. In the meantime I'm working on the battery enclosure.PorkChopsMmm wrote: »Yes, please post pictures. I too have struggled with tilt-mounting panels on a steel roof -- I didn't want to pay the Iron Ridge price.
