Almost There...
Photowhit
Solar Expert Posts: 6,006 ✭✭✭✭✭
Almost there, lots of spaghetti, and I basically converted the E-Panel into a DC-disconnect box, I'll trust the breaker at the other end and the internal fuse and shut offs in the inverter for now. I hope to have a proper inverter in time, but likely I'll have a second Prosine installed above the current one. Just need a ground on the 2nd charge controller and wiring up the battery(on the ground on the right, in the newly built box) and the inverter.
The arrays comes in from behind, upper back in the E-Panel. The cedar chest is where I had the golf cart batteries to commission the system.
Re: Almost There...
PW, what is that small box under the left-hand Classic? I like the staggered look. What about heat dissipation? enough space between them, inside a closed box?
Re: Almost There...westbranch wrote: »PW, what is that small box under the left-hand Classic? I like the staggered look. What about heat dissipation? enough space between the, inside a closed box?
It's a junction box, I have yet another array to attach to the system, and there will be a third Classic where the PVC connector sticks out a bit. I didn't want to take it back down to drill it out. There was nearly no other way to connect 2 Classics, no less 3.
I think there will be enough space between them, I had planned on spacing them about an inch apart, I may still have enough play in the wires to do that, I had actually forgotten to add a space between these, there is about 1/2" now. I've seen 2 classics sandwiched between 2 E-Panels with no spacing, but I know this is not in a controlled environment. (I will have a fan at the top left and about a 10x10 air filter at the bottom right, you can see the wood panel (that belongs inside) nailed to the bottom.Home system 4000 watt (Evergreen) array standing, with 2 Midnite Classic Lites, Midnite E-panel, Magnum MS4024, Prosine 1800(now backup) and Exeltech 1100(former backup...lol), 660 ah 24v Forklift battery(now 10 years old). Off grid for 20 years (if I include 8 months on a bicycle).
Re: Almost There...
someone else today mentioned that they had left a ventilation gap behind the Classic and used a small CPU fan 4X4(?) to add air movement... they were worried about the body acting as a heat sink.
- 651 Solar Water Pumping
- 611 Discussion Forums/Café
