Proper labels
edpotx
Registered Users Posts: 9 ✭
hello all
Does anyone have a contact to get the proper electrical labels and stickers to be code compliant?
Re: Proper labels
Not sure exactly what labels you need but these threads may help:
http://forum.solar-electric.com/showthread.php?8599-Source-for-Warning-Label-and-Signs
http://forum.solar-electric.com/showthread.php?6935-NEC-Permanent-Label-Requirements
http://forum.solar-electric.com/showthread.php?9476-PV-Labels-for-Enphase-system
http://forum.solar-electric.com/showthread.php?15206-engraven-permanent-sign
http://forum.solar-electric.com/showthread.php?17382-From-where-to-get-electrical-warning-lables
http://forum.solar-electric.com/showthread.php?10150-Warning-Labels
At least one forum member makes such labels for a living. I'll see if I can turn up which one. -
Re: Proper labels
The oh-so-obvious answer: the member's name is LabelEngraving.com
(Not a recommendation or endorsement.)
