Page 1 of 2 12 LastLast
Results 1 to 10 of 13
Thread: Warning Labels
  1. #1
    Join Date
    Oct 2008
    Location
    North Alabama
    Posts
    36
    Default Warning Labels
    I have read lots and lots about warning labels but nowhere does nobody say anything about color. They all appear red when I view them online but is there any requirement that they must be RED?
  2. #2
    Default Re: Warning Labels
    I think it's up to the local inspector, you might want to consult him/her with a sample printout whether it's acceptable. I've seen labels passed inspection with black text on white back ground and a simple red "lightning" symbol or just "WARNING" in red, the rest is black on white (to stand-out and catch attention).
    GP
    Be greener and may the force be with you
  3. #3
    Join Date
    Dec 2010
    Location
    I can see Mexico from my back yard
    Posts
    210
    Quote Originally Posted by Macaw View Post
    If you are thinking about printing your own you might want to check on how well your printout survive sunlight. I printed my own labels for my workshop solar and they didn't last 4 months before the sun bleached them white. Even the ones one the inside faded quickly.
    Note: this was from an inkjet printer, laser printouts might last longer.
  4. #4
    Use a local "car wrapper" shop. They have vinyl stickers that is weather & UV resistance. If you are handy, use photoshop et al. to make a vector graphics EPS format. Fit everything on a 8.5x11 or so sheet and cut out the individual decals yourself. It's cheap this way.
    GP
  5. #5
    Your utility may have some requirements also. Mine recently changed itís requirements for solar labels to this: (stickers and engraved plastic no longer acceptable)
    NOTES:
    1. Signs shall be pop-riveted to cabinets.
    2. Signs are stainless steel, 0.015" thick (min.) or aluminum 0.059"
    thick (min.) with raised or impressed letters 0.01" (min.). Capital
    letters 3/16" min.,small letters 1/8" min.
    3. All pop-rivet holes are 1/8" dia. (typ.).
  6. #6
    My utility had a pdf document that spelled out the color, size, text and mounting method. I noticed my utility required red, my sister's utility in CO required yellow. I'm sure the NEC's will step in one of these days.
    My guess would be to follow local codes by the utility, call them. I spoke to the utility twice about the signs I had to post.
    10.125KW Netmeter System, (3) 15 panel arrays
    (45) REC225PE-US + (45) M190-72-240-S12
    SolarMount I Racking
  7. #7
    Join Date
    Jun 2003
    Location
    pittsburgh, pa
    Posts
    10,289
    even if the nec gets into the act, local governments can still require whatever they want or even none at all if they put it in writing so as no insurance company can fault the home owner. now would an insurance company deny a claim for a small warning label or sign even if it had nothing to do with a failure? you bet they would as they are out to make money and not give it away. just look at the numbers for disasters that had claims denied for frivolous reasons. hmmm, i'm sidetracking here, but my point is that even where the nec is adopted into law that the final word is up to that local government and they can even drop a requirement of the nec altogether if they so choose to do. it is the local governments that make laws and not the nec.
    NIEL
  8. #8
    Join Date
    Oct 2008
    Location
    North Alabama
    Posts
    36
    The latest issue (FEB-MAR 2011) of PVProfessional magazine has an article on labels and recommends adhesive backed UV tolerant labels long used in the nuclear power industry. They also outline the color requirements from OSHA and ANSI specifications as NEC does not call out color requirements.
  9. #9
    Solarguys Guest
    If anyone needs labels (UV rated) I be glad to help. ThanksName:  IMAG0760.jpg
  10. #10
    solarguys, are your lables UV tolerant?
    System: 2kw Kyocera KC130's, OutbackMX60 controller, SW4024, Trimetric metering, 24 volt Hawker Powersafe AGM
    Backup: 1-ProSine 2.0, grid charged 12 volt GNB AGM battery, 15kw Diesel Genset
Similar Threads
  1. battery labels and amp hours.
    By Skippy in forum Solar Beginners Corner
    Last Post: January 5th, 2014, 16:23 PST
  2. Proper labels
    By edpotx in forum General Solar Power Topics
    Last Post: May 29th, 2013, 19:55 PDT
  3. WARNING - Suntech panels - WARNING
    By bbbuddy in forum Solar Beginners Corner
    Last Post: September 15th, 2012, 16:01 PDT
  4. Energyguide Labels Explanation Needed
    By sub3marathonman in forum Energy Use & Conservation
    Last Post: February 24th, 2011, 2:28 PST
  5. PV Labels for Enphase system.
    By mr.radon in forum PV Installers Forum - NEC, Wiring, Installation
    Last Post: October 12th, 2010, 16:57 PDT
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
