Battery charging - Solar Plus DG Set
Re: Battery charging - Solar Plus DG SetYes, I figured that out. Actually I was planning to trigger it with the same power lines, but I realized its not possible. So will be triggering it with a 230V to 12V Transformer connected to main line with fuse.
There are relays that are powered by AC coil. For example, this one, will work on 230V AC snd can switch up to 30A and up to 28V DC. It is easier and cheaper than using a transdormer and rectifier to switch DC-coil relay. -
But such things are not available locally. Thats why using DC coil relay -
Re: Battery charging - Solar Plus DG SetBut such things are not available locally. Thats why using DC coil relay
I am not 100% positive, but I think DigiKey ships worldwide.
- 626 Discussion Forums/Café
