Charging Trojan T105 batteries
Pablox
Pablox Registered Users Posts: 3
Just stumbled on this forum, and although slightly off topic, someone maybe able to help.
I am about to purchase 4 of Trojan T105 deep cycle batteries to put in a rarely used JLG access platform.
i.e 24v (4 x 6v 225ah batteries)
I will be charging the batteries after use, to 100% by the normal built in mains charger, but given the cost of the batteries, I was wondering what wattage solar panel and what controller etc. could I leave permanently connected to keep the batteries in good shape.
I live in Ireland (not very sunny lol).
    Re: Charging Trojan T105 batteries
    Welcome to the forum.
    Trojan is a sort of industry standard battery, but they have some fairly high requirements for charging. For instance in a 24 Volt system they recommend an Absorb Voltage of 29.6. In order to achieve that you need a programmable charge controller as most of the inexpensive ones will not go beyond 28.8 for 24 Volt systems. Further to that you'd want a peak current around 10% of the 20 hour capacity, and that means 22.5 Amps. To get that from solar you are looking at:
    22.5 * 24 / 0.77 = 700 Watt array and a good MPPT type charge controller. Plus a sunny day. :D
    If you don't have the sunshine you can increase the array size (more money) and limit the maximum output of the controller so that it doesn't go over on a good day.
    This is, btw, very similar to what I have on my system.
    Is this a scissor lift? Doesn't it have a battery maintainer built in?
    If so park it in the shade and leave plugged in and check the water every Monday when you come into work...
  • Pablox
    Thanks for the replies, it is a scissor lift, with a built in charger.
    I only have it for home use and it might be a month or two between charges, so I thought rather than keeping it plugged in, a small solar panel might suffice, as I would only need to replenish the batteries self discharge.
    Pablox wrote: »
    That is a different situation. Maintenance charging is much easier to accomplish and does not require as much panel or controller. You really only need current around 1-2%, or about 5 Amps. That would only need about 175 Watts of panel (curiously, one of the Sharps I use which regrettably aren't made anymore).
    So you'd have something like this: http://www.solar-electric.com/powerup-bsp185-24-185-watt-monocrystalline-solar-panel.html
    Controlled by something like this: http://www.solar-electric.com/ss-10l.html
    With this I wouldn't worry too much about having exactly the right charging Voltage as it will more or less be keeping the battery floating rather than doing a full recharge. And very much cheaper than a total solar charging system.
  • Pablox
    Thanks again, yes that's what I meant, but I didn't express it very clearly in the opening post.
    That sounds like what I need, afterI use the scissor lift, I will charge it to 100%, I just want the panel to keep the batteries in good condition until the next time, I use it.
