Solar Irradiance -> Watts
quique
quique Solar Expert Posts: 259 ✭✭
If my location's solar irradiance average is 4.93 (kWh/m2/day)...
monthly and daily variations notwithstanding, I can get 4.93kWh/m2 each day.
how do i convert this to energy produced by a panel?
If I have a 300W panel, (lets ignore efficiency losses), this means the panel produces 300W of power at STC which includes 1000w/m2.
I mean, if I have 5 hours of sunlight, ok, Ill get 5 x 300W = 1500Wh in a day ,but how does 4.93 vs 4.00 vs 6.00 affect my 300W production of electricity?
    Re: Solar Irradiance -> Watts
    You can not ignore the efficiency losses because of the great big one: panels themselves are less than 20% efficient. Most poly panels are about 16% and most monos about 18%.
    You want real data: PV Watts provides; http://rredc.nrel.gov/solar/calculators/pvwatts/version1/
    Photowhit Solar Expert Posts: 6,016 ✭✭✭✭✭
    First are you grid tied? or off grid?
    Grid tied I think you can expect close to 75% of the panel rating x the irradiance as an average for the year.
    Off grid other factors come into play and 52% max depending on how much loss you need in your system for battery health.
  • NorthGuy
    (300 W) / (1000 W/m2) x (4.93 kWh/m2/day) = 1.48 Wh/day
  • quique
    Ok so with pvWatts, 1000kW provides whatever the data here says it does.
    For Central America, La Mesa/Pedro Sula:
    So 4kW worth of solar panels (about 13 of these 300w panels), with the 0.77 derate factor, with tilt equal to its latitude, 15.45, produces:
    4,962 kWh per year.
    I guess what I wanted to know is how the solar radiation of say, January (4.61) results in 386 kWh for that month.
