How do i fix an Old rusty inverter
quique
Solar Expert Posts: 259 ✭✭
I have a couple of inverters that have been stored in a humid climate for about 2 years. Some parts like cable-terminal connections look rusted.
What if anything can I do to restore them to working order?
Re: How do i fix an Old rusty inverter
I doubt there is much you really can do.
I think with electronics and long term storage, "prevention" is the "cure".
You'd need to store stuff like that in a dry cool environment or at the very least sealed in air tight containers / bags with desiccant.
But others might have more. Sry. -
Thx, yes I agree, prevention is key -
Got any pictures? Salvageability will depend largely on how severe and extensive the corrosion is.
At some point there is a limit between how much time/effort/money you sink into trying to resurrect and old piece of equipment and replacing it with new. Some of that will depend on just what the old one was too: a "no name" MSW inverter isn't worth much effort when you see how inexpensive a new one is. -
have you looked under the covers? if there is a 'bit of rust' on the outside, you never know what the inside looks like?
Did you try cleaning off the terminals? How did that go?
And like "westbranch" said, you want to open it up and see how bad things are inside. A lot of the older inverters use large components instead of surface mount ICs and can stand a little corrosion and are easier to clean. Some have conformal coatings sprayed on to prevent any corrosion.
Generally, you can use pure 100% alcohol to clean a circuit board. You want to spot clean if you can.
- 611 Discussion Forums/Café
