Are these Batteries useful for Solar
Jaug
Jaug Registered Users Posts: 8
Hey Guys,
I am looking for batteries for my first solar project. I ran across this:
http://www.npstelecom.com/pdfs/Dyn_UPS/UPS_12-370.pdf
They are used, and "suppose to be 2 years old." I am not sure what all the specs are telling me. I am very cautious about buying things.....Please shoot this down if it is a waste of time.
Thank you for any input.
Best Regards,
Jim
  • inetdog
    Re: Are these Batteries useful for Solar
    Jaug wrote: »
    Hey Guys,
    Three inputs:
    • If you can get then close to their scrap value as lead, it may be worth a try, especially for a learning project.
    • It is important to know that they have been kept properly charged, but if they were in a UPS most of that two years that part should be fine too.
    • This kind of battery is designed for a small number of high current discharges (when the power goes out) but a very small number of charge/discharge cycles. (just sitting there most of the time.) That is not good for use in off-grid solar PV, since they will cycle, sometimes deeply, every day.
    SMA SB 3000, old BP panels.
    what use do you plan to use them for? how many do you want ( for end voltage)?
  • Jaug
    I had plan as off grid / back up. Many power outages here so would run a few items daily. I really don't think this is what I am looking for. On craigs list $75 each.
    Best Regards,
    Jim
    You may be right, if you post just what it is you want to run (in Watts per appliance, light etc and total Kwhr), we can guide you to a planned out setup...
    as to the batteries these are a good brand, but they are used and you really don't know if they are any good or not. you take a chance on used batteries. unless it can be proven they are good then offer scrap rates as was mentioned.
