Update firmware on a XW6048
Clif
Registered Users Posts: 17 ✭✭
I have the newest firmware from the Schneider website but how do I install it? Anybody have the teck support phone number? Thanks.
Re: Update firmware on a XW6048
Looks like they haven't had any firmware updates for the long time. Most people have the latest 1.07 firmware. -
You need an "implanter" (beg, rent, buy) or one of their (rare) communications gateways (I believe). You might contact the folks you purchased the XW from and ask them (something like $250 for implanter, might rent for $25 + shipping costs).
Re: Update firmware on a XW6048Looks like they haven't had any firmware updates for the long time. Most people have the latest 1.07 firmware.
If I had the latest I wouldn't need to update! -
If you have a gateway, tech support can make a file for you that will implant the firmware through the gateway. They don't put those files (.wie extension) on the web site but I have called them in the past and they emailed me the file. If you dont have the gateway, you will need the CANBUS implanter tool. -
And the warning with the gateway, the gateway, inverter & SCP will stay powered with heartbeat power, but the AC will shut down. You need an ethernet router you can power from a battery, while the firmware is being loaded. You don't want to brick the XW - shipping costs for that will be expensive.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
- 231 Forum & Website
