Is there a voltage tolerance that that should be taken into account?
rdemart44
Registered Users Posts: 7 ✭
When running dc products i.e. a 9 volt transistor radio, 12 volt TV etc. how close do you need to get voltage wise not to have problems. As an example: lets say I want to run a 12 volt TV directly out of my charge controller which right now is 13.3 volts. Will this voltage be fine or do I have to get closer to the 12 volts?
Re: Is there a voltage tolerance that that should be taken into account?
Unfortunately the answer is: it depends on the particular device.
Most things design to run from "12 Volt" auto source have a pretty wide tolerance, certainly +/- 10% from the usual 13.8 Volts (some vehicles run higher, some lower). Some 12 Volt inverters are notorious for shutting down from "over Voltage" is you EQ the batteries at 15+ Volts.
What do you mean by running "directly out of my charge controller"? Is this a controller with "LOAD" terminals on it? Even so it will need a battery to provide stable Voltage levels (as discussed previously in another thread).
In the RE world the absolute low end on a 12 Volt system is 10.5 Volts and the upper end for charging is usually 14.8.
Sorry that's not a very definite answer. There are some things you can do if you think the Voltage might go too high, such as putting a diode in series with the power to knock half a Volt or so off. If it's a really critical device then some type of specific Voltage regulation would be in order. -
That is really hard to say... For example, some of the "12 volt adapters" (laptop, etc.) have been known to smoke when taken above ~14.2 volts.
For an off grid power system, a 12 volt battery may see 14.8 to 15.0 or even 16.0 volts during some charging conditions (sub freezing battery bank, during equalization, etc.).
13.3 volts is pretty much a "low" float voltage for a solar power system... Depending on the battery bank, you might need closer to 13.6 volts--And 14.2 to 14.75 volts for a flooded cell deep cycle battery is pretty much standard bulk/absorb set points.
The charge controller has a 12 volt cigarette lighter plug in it. -
Re: Is there a voltage tolerance that that should be taken into account?The charge controller has a 12 volt cigarette lighter plug in it.
I've never seen such a thing. Do you have a make & model so we could look up its specifications? -
sounds like one of those C-Tire "power packs" that can be recharged from 110/12v/pv, last 2 through a cig lighter plug...
It's the one that comes with the Harbor Freight solar panels which I think is 4 amps. It also has a 3,6,9 and two more 12 volt jacks.
