Effect of 2 panels in series
aparker
Registered Users Posts: 2
I'm still trying to understand the TLIs and FLIs (Two/Three and Four/Five Letter Initialisms) associated with solar equipment.
I have a panel with the following specs:
Voc = 45 V
Isc = 5.5 A
Pmax = 190 W
Vmp = 36 V
Imp = 5.0 A
If I connect two of them in series, assuming I'm operating at the standard conditions and dealing theoretically rather than real world, in theory should the two panels just follow Ohm's law?
i.e. For 2 in series the array would have these specs?
Voc = 90 V
Isc = 5.5 A
Pmax = 380 W
Vmp = 72 V
Imp = 5.0 A
i.e. the voltages and pmax double but the currents remain the same?
Voc = 45 V
Isc = 5.5 A
Pmax = 190 W
Vmp = 36 V
Imp = 5.0 A
Voc = 90 V
Isc = 5.5 A
Pmax = 380 W
Vmp = 72 V
Imp = 5.0 A
Re: Effect of 2 panels in seriesI'm still trying to understand the TLIs and FLIs (Two/Three and Four/Five Letter Initialisms) associated with solar equipment.
Voc = 45 V
Isc = 5.5 A
Pmax = 190 W
Vmp = 36 V
Imp = 5.0 A
Voc = 90 V
Isc = 5.5 A
Pmax = 380 W
Vmp = 72 V
Imp = 5.0 A
Welcome to the forum! And to answer your question - - YES! You have it right! -
Many thanks for confirming that and for your kind welcome
That's why we have the glossary of terms: http://forum.solar-electric.com/showthread.php?6136-Glossary
Correct. Question #2:What happens when you put the same two modules (panels) in parallel?I'm still trying to understand the TLIs and FLIs (Two/Three and Four/Five Letter Initialisms) associated with solar equipment.
Voc = 45 V
Isc = 5.5 A
Pmax = 190 W
Vmp = 36 V
Imp = 5.0 A
Voc = 90 V
Isc = 5.5 A
Pmax = 380 W
Vmp = 72 V
Imp = 5.0 A
i.e. the voltages and pmax double but the currents remain the same? -
And why we have this thread on panel configuration: http://forum.solar-electric.com/showthread.php?16241-Different-Panel-Configurations-on-an-MPPT-Controller
And this thread on battery configuration: http://forum.solar-electric.com/showthread.php?15989-Battery-System-Voltages-and-equivalent-power
And why I have Ohm's law and the power formula in my signature.
