Effect of 2 panels in series
aparker
aparker Registered Users Posts: 2
I'm still trying to understand the TLIs and FLIs (Two/Three and Four/Five Letter Initialisms) associated with solar equipment.
I have a panel with the following specs:
Voc = 45 V
Isc = 5.5 A
Pmax = 190 W
Vmp = 36 V
Imp = 5.0 A
If I connect two of them in series, assuming I'm operating at the standard conditions and dealing theoretically rather than real world, in theory should the two panels just follow Ohm's law?
i.e. For 2 in series the array would have these specs?
Voc = 90 V
Isc = 5.5 A
Pmax = 380 W
Vmp = 72 V
Imp = 5.0 A
i.e. the voltages and pmax double but the currents remain the same?
  • waynefromnscanada
    Re: Effect of 2 panels in series
    aparker wrote: »
    Voc = 45 V
    Isc = 5.5 A
    Pmax = 190 W
    Vmp = 36 V
    Imp = 5.0 A
    Voc = 90 V
    Isc = 5.5 A
    Pmax = 380 W
    Vmp = 72 V
    Imp = 5.0 A
    Welcome to the forum! And to answer your question - - YES! You have it right!
  • aparker
    Many thanks for confirming that and for your kind welcome :)
    That's why we have the glossary of terms: http://forum.solar-electric.com/showthread.php?6136-Glossary
    :D
  • ggunn
    aparker wrote: »
    Voc = 45 V
    Isc = 5.5 A
    Pmax = 190 W
    Vmp = 36 V
    Imp = 5.0 A
    Voc = 90 V
    Isc = 5.5 A
    Pmax = 380 W
    Vmp = 72 V
    Imp = 5.0 A
    Correct. Question #2:What happens when you put the same two modules (panels) in parallel?
    And why we have this thread on panel configuration: http://forum.solar-electric.com/showthread.php?16241-Different-Panel-Configurations-on-an-MPPT-Controller
    And this thread on battery configuration: http://forum.solar-electric.com/showthread.php?15989-Battery-System-Voltages-and-equivalent-power
    And why I have Ohm's law and the power formula in my signature.
    :D
