trying to test a motor
coboda
Registered Users Posts: 6 ✭
I just got a dc permanent magnetic motor off an old treadmill, according to my calculations it should produce 24v @ 450rpm
I'm trying to test the voltage output with a voltmeter by connecting it to the terminals and hand spinning the shaft but I'm not showing any output.
any suggestions?
any suggestions?
Re: trying to test a motor
If you have connected your meter to the right terminals on the motor, and if the motor is indeed a DC motor, and if the meter is good and set to read low voltage DC, then I would expect a problem with the motor. BTW, even if you get the motor to work, IF you are thinking of using it as a generator, do not expect a lot of power from it. Yes, it should give you 24 volts alright, but it won't produce a lot of amps or watts due to it having been wound with small wire, to run as a motor off a much higher voltage. -
I get an ohm reading and a DC amp reading, DC volts only read when my dial is set to 200m, but I get no reading on 200. the motor I got is rated @ 1725rpm 115v and 8.5 amp so techinically if at 450rpm i generated 24v shouldn't that give me about 204 watts? -
Power is not a linear function of RPM.
Spin it with an electric drill for testing purposes.
Don't get your hopes up.
Motors still aren't generators, nor are they designed to last outdoors in weather (if you were thinking of making a wind turbine from this). -
well after messing with this damn thing for two days I just found out it was an ac motor haha -
Re: trying to test a motorwell after messing with this damn thing for two days I just found out it was an ac motor haha
More likely it is a DC motor with circuitry attached to it to make an AC fan module.
Circuitry also called "steering diodes", as mentioned in an earlier post. :-)SMA SB 3000, old BP panels. -
Re: trying to test a motorMore likely it is a DC motor with circuitry attached to it to make an AC fan module.
Well I ended up getting another motor that work, but the other one has a better voltage/rpm ratio so how would I bypass the circuitry? -
It would be helpful if you list the items off the rating plate of the motor,i.e. AC, DC, RPM, Load A, V, HP.
I have a permanent magnet DC motor generator. This is a small set, prop diameter is 7'. I tried many motors before finding one that would work. What you need is a motor that is rated at low RPM and higher amperage. The bigger cased motors usually have bigger windings and that is what's needed. Old school Ohio Electric hard drive motors fit this description but are becoming increasingly hard to find.
I've experimented with higher RPM motors of various sizes and different gear reduction but those have to much torque to be used at typical wind speeds, mounting heights, and with small diameter props. -
Welcome to the Forum, westend.It would be helpful if you list the items off the rating plate of the motor,i.e. AC, DC, RPM, Load A, V, HP.
If you look far enough back in the thread you will realize that the subject is a computer fan, not a motor converted to a generator for wind turbine. :-)SMA SB 3000, old BP panels. -
When he put "other motor" in his last post, I thought we were back to the treadmill motor. Sorry..Welcome to the Forum, westend.
