Entry level NEC approved inverter for off grid
Mike at Energy Commission
Solar Expert Posts: 50 ✭✭✭✭
Anyone know what the least expensive off grid stand alone inverter is that meets NEC for residential install?
Re: Entry level NEC approved inverter for off grid
NEC does not approved inverters; they cover installation. Are you thinking of UL approved inverters?
As for "least expensive" much of that has to do with the capacity of the inverter, and what deal you can find.
Look at the Samlex/Cotek brand. It's reasonable quality and fairly low priced. At NAWS: http://www.solar-electric.com/sasiwain1.html -
thanks looks like UL1741 is what meets code.
- 231 Forum & Website
