Direct TV, DishNet, DVR's power usage, and input power Modifications (Discussion)
13»
  • Logan5Logan5 Solar Expert Posts: 32
    Re: Direct TV, DishNet, DVR's power usage, and input power Modifications (Discussion)
    Front & rear views of the Telus dish. You RF guys can make of it what you will. :D
    I took shots of the Xplornet & Shaw dish as well. The Shaw dish (which is not up) has four coaxial connectors on the horn. I can't tell how many are on the others - eyesight not good enough from the ground.
    This is the same quad LNB "Dish network" uses here in the states. I think it is now listed as legacy equipment. it can have 2 out put's or 4, I have used this LNB to receive both Dishnet and Direct TV as well as FTA satellite signals.
