Mike status update (Lucky Monkeys Ranch)
mike95490
Mike here. Sorry about the long absence, but I'm really off grid, and get internet
via cell phone and oversold 3g data, or go to the public library, and use the service
there. Not conducive to much chatting at all.
Status
Totally moved from Los Angeles, and into the new house which just passed final inspection
on Nov 21.
Heating is mucked up, somehow the mason thought the "heated bench" needed some
insulation to keep it from being too hot. If 55F is too hot, he was right. The bench
surface composes about 30% of what was supposed to be a 140F radiant heat surface.
And if code requires damper to remain 5% open, then 50% open would be a lot better, right?
So the 21 hours a day the heater is not burning, it's thermosiphoning the heat that is supposed
to go into the house, up the flue. Dingbat! I'm trying to heat the whole outdoors, and
folks far north of me, are burning less wood. http://www.tempcast.com/testimonials.html
So I'm very busy hauling a huge cart of wood every couple days. That 2 cords is not going
to last past January !
Currently, we are expecting a monster rainstorm for the next 2-4 days, with 10-20 inches forecast.
Flood warnings are up for tomorrow (Sat) when all that rain hits. We are on a well drained rise,
and above any reasonably expected flood zone.
Solar, I've had several 4 & 5 day runs of clouds, and one 13 day run without getting to absorb,
when big batteries get low, it takes a long time to fill them back up. But I'm not using much water!
Generator(s), Currently, the "big iron" is down, all the gaskets started leaking coolant, and
need replacing. For my spare time, when not hauling wood. Belt alignment is off, and it keeps
throwing the belt, so I have to "tweak" the mounting bolt alignment till it's OK. Tedious.
Since "big iron" never powered up it's alternator, I think either the mice fired the windings (bad)
or the core lost it's residual magnetism. When the belt stays on, I'll diagnose that. And
since no power was coming out, I've not needed to wire up Aux input on the XW6048, so my 3600rpm
screamer is off line. So I'm down to the Honeywell 2000i and the 15A Iota charger. At least
that runs, after 10 minutes of pull cord.
Batteries: Calculating whats going in, and coming out, I'm needing 2 ah charge, to replace 1 ah
used. Not as I'd planned. I've got the carbonate test kit, but have not had time to set it up,
with all the other emergencies (oh, you want to pass final, do this.... and call me back), it
will have to wait it's turn. I'll run the generator between storm cells, and wait for sun.
Wife: Must have toaster. Camp toaster over stove burner, or frypan with butter not acceptable.
So, I've been quite busy, my clothes are spread between 2 storage buildings and none in my closet,
moving in, is the lowest priority. Gotta go, and hope to be back soon.
Mike
    Re: Mike status update (Lucky Monkeys Ranch)
    Good to hear you are still live and kickin', sad though that you are having a long break-in period. Just to fill you in about our weather, its been much like yours for the last 6 weeks, with little usable sunlight, just little squeeks of it. Mot much snow yet just hovering around freezing, waiting for real winter to arrive..
    good luck.
    Eric
  • icarus
    Welcome back Mike,
    Sorry for your troubles.
    As for the toaster,, find a small Coleman catalytic heater,, the kind that screws on a 1#bottle. (if you can find the old style square, flat model, it is way better!). Fashion a wire bracket to hold the bread, and place the bad on the face of the heater. Makes perfect toast in about a minute, and burns for months on a single bottle. (I refill mine from big tanks,, cost nearly nothing). Hangs in the wall or under the cabinet when not in use.
    http://www.ebay.com/itm/Coleman-BlackCat-Perfectemp-Catalytic-Heater-/170945169082?pt=LH_DefaultDomain_0&hash=item27cd2046ba
    Not this square one,, they are too big,
    http://www.ebay.com/itm/VINTAGE-COLEMAN-2000-5000-BTU-PROPANE-CATALYTIC-HEATER-HUNTING-CAMPING-ICE-FI-/110981795226?pt=LH_DefaultDomain_0&hash=item19d707cd9a
    Coleman Canada made really nice square one, about 8"x6", very hard to find these days.
    glad you responded to my inquiry. glad all is fine although hectic.
  • mtdoc
    mtdoc Solar Expert Posts: 600 ✭✭
    Mike,
    I'm curious about your experience with your NiFe batteries. Looks like you've been using them for a while now and the charge efficiency is not great. I realize this is a known issue with NiFe's. It is worse than expected? Other issues? Would you purchase these again?
    Good luck with the move.!
    Dave Angelini Solar Expert Posts: 7,077 ✭✭✭✭✭✭
    Is the day you wrote about your experience, far better than the best day in the aerospace industry in LA ?
    That is all that counts! Good Luck!
    Even though you probably won't see this for a while ...
    Sympathy and empathy from an old man who's been doing the move-in thing for three years now and still can't find all the boxes, much less unpack them.
    At least I don't have anyone making concrete mistakes for me. :roll:
    mtdoc wrote: »
    Mike,
    Well, with the NiFe, I'm not nearly so an&@ about hitting absorb and keeping them above 80%, as I would be with Pb-H2So4. But the initial expense, and the "not the whole truths" from the sales sites, and the frequent replacement (looks to be about 2-5 years) of the electrolyte, and I'm now thinking that a forklift battery bank would be the next step I'd try in 20 years, if I need to.
    Should we change your name(zip-code) to better show your new status? :D
  • Fe-Wood
    Fe-Wood Solar Expert Posts: 96 ✭✭
    Great tip about toasters!
    he might want to leave it the same to remind himself of where he came from.
    Will that muck up my previous posts and such - or is it simple & transparent ?
    mike95490
    I should be able to change it to "mike95490" -- Just use it as your new login name. Should not change anything else.
    Lets give it a shot.
    awesome, thanks
    Not related to the guy formerly known as 'Prince' are you??;);):cool:
  • SolaRevolution
    SolaRevolution Solar Expert Posts: 410 ✭✭
    Welcome to 95490 Mike!
    -Alex
    Welcome to 95490 Mike! -Alex
    Thanks, looks to be a frosty night tonight. Another load of wood into the heater !
